Corrupted bytes with 29C256 on PM7
icedfluid
#1 ◈ 2016-04-04
Hi,
I have a problem with my PM6/7 daughter board from Doc.
It works fine without access to external ROM, but as I put the jumper and boot, the CEL is solid.
I have checked all my PCB for continuity 3 times, and everything is OK.
BUT there is a strange thing : If I remove my AT29C256 after boot ECU with jumper, and plug it on my ROM programmer for read, some groups of bytes are corrupted ! randomly ! On time at the beginning, on time in the middle ! :shock:
I re-test with the pin #1 of 29C256 (Write Enable) don't plug on daughter board socket (in the air), and SAME thing ! 839 bytes corrupted !
I have watched pin #28 of CPU (connected to #1 of 29C256) with oscilloscope and there is a square signal 5V with 60ms period. Is not strange to have A15 of CPU bus connected to /WE of flash ROM ??? (16 wire to access 32k ?)
Is anybody can help me ? Idea ? :roll:
Thank you !
icedfluid
#2 ◈ 2016-04-04
I have strapped 5V on /WE of 29C256, bytes don't go anymore :lol:
But always a solid CEL ...
AT29C256 really works on Doc daughter board !???
It seems that square signal on #28 CPU (A15) destroy the flash rom content ! :evil:
Is A15 really needs with only 32kb to access ???
doc
#3 ◈ 2016-04-04
No, A15 isn't needed for 32k access.
Cut the track from CPU pin 28 to Eprom Socket Pin 1.
Connect only the Eprom Socket Pin 1 to VCC (Eprom Socket Pin 28).
Tested and working.
Doc
icedfluid
#4 ◈ 2016-04-04
Thank you Doc !
I will try this, but when I strapped 5V on FlashRom pin #1 (yesterday), I had a solid CEL to. ;(
More informations later !
icedfluid
#5 ◈ 2016-04-04
It's OK, it works fine with a *good* BIN ! :lol: :lol:
