infotechplus
#1 ◈ 2017-03-14
I am almost finished my JDM B16A2 and am looking to modify the ECU to work with ECUControl. The ECU is a P30 930.
We will be adding a serial port.
According to information here and on the ECUControl web ...
"R54 should be filled with a 1k to 1.2k resistor(the exact value does not matter). C51 and C52 are 0.1µf ceramic disc capacitors(12V or better will work fine). "
This ECU is different to the P28 pictured and both myself and my assistance (trained electronics guy) cannot find R54, C51 and C52 anywhere on this ECU.
I have attached a photo of the inside of this ECU. It has a daughter board attached via ribbon cable.
I would appreciate some assistance here.
Peter
