Free (open) rom editor
AllGo
#1 ◈ 2020-09-24
[url=http://tunetoy.sourceforge.net/]
Hi there,
I decided to dump my rom editor (or at least some very old version of it, i hate hard disk crashes) on sf.net . If there's still any interest in it, I'll try to fix it up (probably I have enough interest in it to fix it up for my own needs), otherwise, it will die a silent dead on sf.net.
What it does now:
- You can alter fuel and ignition tables on P30-203 roms
What it doesn't do yet:
- Everything but editing fuel and iginition maps.
AllGo
[/url]
luti
#2 ◈ 2020-09-24
i am currently downloading eclispe as to your mention of it on the sf page. but i have a question as im no java expert, why does your program require eclipse to run? I was always under the impression eclipse was a tool to build in, thats all we ever used it for in class. I didnt think it had its own librarys....
AllGo
#3 ◈ 2020-09-24
Eclipse certainly has it's own libraries (SWT is a well-known example), and since 3.0 you can build complex applications in a relatively simple way. Google for 'Eclipse RCP '...
AllGo
#4 ◈ 2020-09-24
20050304: Page updated, there are detailed build + installation instructions available. Anyone can do it now 8).
luti
#5 ◈ 2020-09-24
man the version of eclipse we were using must have been really old or severly different for solaris then for mac os x (what i use at home) cause i was so lost in it for a while yesterday when i was inspecting your code.
#6 ◈ 2020-09-24
Nice. I'll make you a forum for your editor here.
luti
#7 ◈ 2020-09-24
so i thought it was just me fucking up, so i followed your above directions and i get about 17 compilation errors. im using jre 1.4.2 on mac os x. i can post an error list later if you are interested...
AllGo
#8 ◈ 2020-09-24
There might be some Java 1.5/5.0 code in there. Is there a Java 1.5 distribution for Macs? If not, I'll backport all code soon, since I'm going to do all development on it from a Mac.
Anyway, you can send the problems to my email adress which is listed as my msn messenger adres in my profile.
Thanks for the feedback.
AllGo
#9 ◈ 2020-09-24
Not needed - I've backported it to JRE 1.4. Indeed I was using a couple of Java 1.5 constructs. Update and you will have succes :).
Btw: nice to know it's being tested on other platforms than Win32 as well :).
luti
#10 ◈ 2020-09-24
now all i need is craig moates to port his chip burning software to mac. he said i could do it and hed help me out with the protocol, but my programming skills arent quite that good...
AllGo
#11 ◈ 2020-09-24
A port to Java would be even better (platform independent).. I can do it, if I have the source/specs/something...
luti
#12 ◈ 2020-09-24
ill have to remember that... going to check out your editor first, then ill get in touch with craig.
toxicshit
#13 ◈ 2020-09-24
yo robin keep ut the good work ! looks nice and the options work nicely :D
