JET ECU
Tim
#1 ◈ 2024-11-30
I found a Jet ECU for less than $40. It's for my '89 CRX DX 5spd and owner claims a 5-10hp gain. Does anyone else have experience with JET ECUs and is it worth it on a stock DX? I plan on adding a cat-back and cold air before the end of this year. Thanks!
#2 ◈ 2024-11-30
Re: JET ECU
how about you come pick up the Si engine in my garage for a performance upgrade?
DX is not a performance engine. COmputer upgrades aren't going to do @!#$.
oldskool_rex
#3 ◈ 2024-11-30
I can agree
The Si intake manifold and ecu would gain much more in the way of power.
Mike Robichaud
#4 ◈ 2024-11-30
Re: JET ECU
Was this Jet ECU meant for the DX? I have never seen an after market chip for the DX. You might be looking for a MPFI swap before you can even use it. I'd love to see the bin for that chip though...
Mike
91crxsi
#5 ◈ 2024-11-30
Re: JET ECU
Hey, Tim,
If you have the means, it would be great if you could send me a copy of the ROM. I could probably tell you whether it's doing anything. Most of the aftermarket ROM's I have seen (the ones you pay hundreds of dollars for) do little more than tweak the fuel and ignition maps by a few percent and remove the rev limiter completely (dangerous!).
91crxsi
