0-5v O2 Sensor Input
JapanPAssion ¬¬
#46 ◈ 2025-05-21
Re: 0-5v O2 Sensor Input
mmmm...
hi guys..
I read the post and bump for this good idea.. but..
I have crome Pro and PLX AFR-WD 5volt blocked
We have another way to read the 20AFR without ecu modding?
If not..
how can i read it onto the ELD pinout on crome tuner?
sorry if the matter is spoked but i don't find the post...
turbo_eg
#47 ◈ 2025-05-21
can you install the stock o2 sensor back on the car if you do this mod
Smooth1
#48 ◈ 2025-05-21
Of course.
B20vDB8
#49 ◈ 2025-05-21
i know this post is old but im trying to this mod to my ecu , is it saying we r adding a 10uf cap to make it work or just add a jumper from the cap to r5 ???????? :roll:
ben_deez
#50 ◈ 2025-05-21
Orange_SIR
#51 ◈ 2025-05-21
would this mod be very beneficial or i can go without it?
RicardoNC
#52 ◈ 2025-05-21
If you limit the wideband output AFR readings to 0.06~3.8 volts, you dont need the mod.
The mod implies open-loop tunning/operation.
ben_deez
#53 ◈ 2025-05-21
you get a way more accurate reading with 5 volts... for me, tuning is all about accuracy plus the lc-1 was made for 5v opperation..., any thing else is questionable as far as accuracy
scanikwwo
#54 ◈ 2025-05-21
For all the people who still ask how to do it:
Here's a little pic found in topic about 5v mod (made by acidz_z6) and edited it to be correct. The red line is the jumper mentioned above (it is suppose to be on the bottom side of PCB).
