do you need to run a missing link whith chrome
Crome eliminates the need for a missing link. If you run one you are pretty much screwing up its ability to read boost.
Yeah the whole point of check vavles and missing link is to keep the stock map sensor from going over a certain voltage. The stock ecu code isnt able to read boost
However when using crome and boost code the ecu has the abilty to see postive pressure and it knows what to do with it. So check valves / missing link isnt needed
