M2Prelude
#1 ◈ 2024-11-02
***Here is the problem***
We chipped his stock P28, added datalogging (which works with ECU control... very cool), and extra features using a USDM P72 codebase with knock disabled. Knowing the output needed to be 12v for the IAB, I did the ODB2 version of Add IAB to P28. The IABs did not function with the P28, but did with the JDM P72 after our rewire.
On the P28: I have pin 1 of IC15 desoldered from it's hole, and jumpered to hole C of Q34. I have c61 in place with the proper polarity.
Somewhere I read that you need to switch A17 to A19 after this mod... tried that and it didn't work either.
here is some shots of my work... did I do it right?
The brown thing you are seeing in the corner of the pics, is the max233 serial pcb I made.
Any advice would be appreciated! I will do some more troubleshooting tomorrow, and hopefully this will help someone else in the future!
**edited to add comment that we moved A20 to A17**
