jonnyvtec wrote:
Looks great
How does keyboard quick edit work?
I'd say...read the help file, dude !
but here it is :
KEYBOARD
_ use the arrow keys (left/right or up/down) will toggle the focus beetween maps
_ use the keypad keys to move/edit :
MOVE
8 : up / 2 : down / 4 : left / 6 : right
1/7/9/3 : diagonal moves
EDIT
5 : edit current map point (same as mouse edition)
+ : adds 0.1 to current value
- : removes 0.1 to current value
* : adds 1 to current value
/ : removes 1 to current value
ADVANCED EDIT
COPY/PASTE
C : copy current value
V : paste copied value to current position
B : paste copied value to current position and jump to the next datapoint
INTERPOLATE
this will smooth the map points in an average straight line from the start point recorded (if none, from 1/1) to the end point
D: Record Start point (default is 1/1) for both maps
F: Select End point and do X interpolate (horizontal) in the current map
G: Select End point and do Y interpolate (vertical) in the current map
Quote:
When you double click on fuel values to change them the box that pops up refers to ignition and has the current ignition value, changing it and clicking ok changes the fuel table tho.
bug fixed (version 6.3.9)
keep on reporting bugs, I'll fix'em up !
