Willem Dual Powered Programmer and SST 27SF512
CyberShoot
#16 ◈ 2025-10-06
Re: Willem Dual Powered Programmer and SST 27SF512
user: machine
I see that you understand about this i have the Willem pro 4 no jumpers only dip switch what is the settings that you use on your willem.
THanks
meet07
#17 ◈ 2025-10-06
what do you do when the red error at the bottom pops up....
Hardware Error : Check Power & connection.
Power is hooked up and everything. Ive used the burner plenty of times in the past and now its not working. I have noticed that the bare metal tab beside the usb white cable on the board has a lil brown around the sordering connection on the opposite side of the board.
