TurboEdit and Ecucontrol have obd0 WB02 log capable?
slowsi
#1 ◈ 2013-01-19
i have a question i have tried almost every version of TE and Ecucontrol out there and nobody seems to have an obd0 wideband 02 log working.
also its very hard to navigate now that its open source because theres some other guy making TE 2.6.2 ??
and what happened to TE 2.5.5 that is nowhere in the CVS sources, what is going on....
can anyone help me with whats going on with this?
or point me in the direction of other software that can log innovate's wideband controller
slowsi
#3 ◈ 2013-01-19
ive seem to have caught up with hours of reading... but still
ok my main question is how should i set my LC-1 wideband controller to output to the ECU, right now i have it set to 0-1 volt to imitate the narrowband sorta.
should i set it to work with 0-5volts ? or will that fry the ecu.
i actually pm'd johnnyvtec because he uses LC-1
i am assuming i want 0-5v analog outputs by the indirect comments
jonnyvtec
#4 ◈ 2013-01-19
You need to use Analog 2 output with the std range of 0-5V
The ECU can read up to 3.8 V, this should be fine for logging the AFR on the map trace in terms of WB Voltage, using the narrowband simulator will tell you rich or lean, which is pretty much useless.
