Yuleluder
#31 ◈ 2016-04-05
Where did you get your Distributor? Would you mind telling me about your conversion harness, specifically how you made it? The OBD 1 hybrid distributor I used the CYP sensor was grinded down so I could swap it into my OBD 2 Distributor, so I think it was bad anyhow. Funny I should have tried the OBD 1 Dizzy, before I hacked into it and modified its CYP sensor. I ended up blowing the rings in cylinders 1 and 3 because I had the hybridized Distributor wired up but I forgot to fully tighten down the Dizzy, which caused misfires in cylinders 1 and 3. I'll be replacing the rings this weekend, and my new custom header from six sigma racing will be here. So I definitely want to get this thing tuned. I would defintely appreciate your help on the conversion harness. Did you hack into the engine harness in order to get to the CKP, and TDC wires, or did you run the wires directly to the ECU? Have you tried your P5 with the OBD1 ECU?
